Unlike most of the friends here, the Legacy and me are in China. I'm pretty sure that this legacy is the only one that still running in my city now, furthermore, one of less than ten(or even five) in the whole country. Maintaining this vehicle is quite difficult, even the dealer don't know how to repair it. Vehicles like this old Subie, are not imported officially. I feel lucky to own one.
Recently, I lost the water temp gauge on the cluster. Thus I was doing some work on the electrical fix. Till now, A 15V 83F super capacitor is added to the battery for a steady voltage, and to support sudden electrical needs for acceleration or so. It works fine, but no significant improvement there.
I got a multimeter, then I measured the voltage that send to the one wire thermistor is about only 2V. After the installation of the super capacitor voltage stabilization mod is added, The water temp gauge could point to the right position occasionally, while pointed to cold otherwise. It will point to the middle in these conditions:
a. Release the throttle and slide with the gear on.
b. Pushing the throttle in reverse gear.
c. Stop in front of the red light.
It is really buzzing me. Thus I go to the groundings last night. I cleared two ground points on the strut towers. and check the fuse box. I have this unstable idle unstable problem. And I noticed that the rev will jump slightly with the click of AC Fuse No.3. Thus I took the fuse box up to check the connections, all seem good.
After all that, this morning when I start my car, I found out that both of the fans will be on with the key turned to ON, along with hard to start. Actually this happened last night in a very short time, I just reinstalled the fuse box, and it gone.
Thus I drove the car to a factory. They checked all the wires in the engine bay, remake the connectors of the temp sensor, tested with another good temp sensor. Still, the fans are on all the time as long as the key is turned to ON.
Here is some facts:
a. After the check of the wires, the voltage to the one wire temp sensor is going to 8-9 V, Thus the temp gauge is back with wrong position.
b. The A/C switch is gone. It won't light up and no relay clicks can be heard. Compressor is not working(cycling with belt) no matter how.
c. The GE ground point is well grounded to the battery terminal. However the chassis are not, there are about 1.5V between chassis to the battery negative.
d. Take out all the relays on the fuse box in the engine bay, the fans are still running, but the rpm seems lower. relays seem fine. Also some of the relays under the cluster are tested, found on for the main fan, but it is OK too.
e. Tested several pins on several sensors, the voltage of the ECU is sending is about 5.1V.
f. there is a grounding wire between chassis in the fuse box area and the battery. Heat is noticed on that wire. Disconnect that wire, the RPM of the fan seems lower. And there are sparks when connect it to the chassis, while the fan is running.
g. all these are observed with or without the super capacitor connected. Thus I think it won't do anything to the problem.
Another fact:
It has been a while, that the unstable idle will come with the clicking sound that from the left side of the cluster. This clicking also happens in the driving. But after today's engine bay wire check, it is gone for now.
check the video: http://www.youtube.com/watch?v=wr7ClWuY ... e=youtu.be
What I am going to do is grounding the chassis as best as I can. But no hope on solving this problem.
Any suggestions will be welcomed. Thanks in advance.
P.S. Under the strict laws and regulations in China, owning and maintaining an old car is very hard. Now I have to take the legacy to the government test center twice a year to get the permission to go on the road. And if the vehicle's mileage reach 600,000 km, it will be force retired to the garbage tray. I really want this one to run longer, please help me out!
