200K timing belt relacement. What else to replace?
Scuba75
Post by Scuba75 »
Hi everyone. First post on the forum. Thanks to everyone for sharing their knowledge, this forum has taught me so much and saved me big$$$.
So, I'm having my timing belt replaced this week. I feel it is a little above my mechanic ability at this time plus I have a local Subaru mechanic that charges 50 bucks an hour!I bought a kit from ebay that includes the belt, roller, idlers, water pump, front seal, and 4 cam seals. The mechanic is charging me 200 bucks to do the job, really cheap for this part of California. Anyway, is there any recommendations as to other things I should have done while he is doing the timing belt? Things that are easy to do while the timing belt is off? It's a 93 wagon non-turbo with 200K miles on it. What about the oil pump? Any recommendations are greatly appreciated. I want her to go another 200K!
Cheers!
208ss
Re: 200K timing belt relacement. What else to replace?
Post by 208ss »
Be careful with eBay you never know what you get. With that said do spark plugs why your at it.
1991 subaru legacy sport sedan
208ss
Post by 208ss »
When he's in there good idea to do water pump if it has not been done yet
ride_child
Post by ride_child »
Kris
'91 Mica White SS - R.I.P.
'91 Black SS - SOLD
You mention that the timing belt kit has four oil cam seals. I would highly recommend checking whether it's the correct belt/kit because the EJ22 only has two front oil seals and one o-ring on the rear passenger side head.
wtdash
Post by wtdash »
^ I believe Josh meant to state "...highly recommend CHECKING THAT it's the correct belt....".
The 2.2 is a S(ingle)OHC not the D(ouble)OHC of the 2.5.
I'd also suggest resealing the oil pump. There are 4 screws on the back of it that can come loose and an O-ring to replace. Also, inspect the oil pressure sender - between the P/S pump and Alternator on top of the engine. It commonly leaks - easy and cheap to replace.
GL,
TD
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Yes, that's what I meant, sorry about that.
Todd, thanks for catching that for me!
