Bypass Valve
Front, Top, Air, Water.
Naked Buell
Bypass Valve
Post by Naked Buell »
Hey guys. I was wondering if any of you knew of a good site to get a stock bypass valve. I have an sti intercooler that is going on my 2.2T and need the bypass valve.
Thx
86 Brat, 2.2T, AWD, TD04, Intercooled,
88 Rx, Future EJ upgrade soon
Re: Bypass Valve
wtdash
Re: Bypass Valve
Post by wtdash »
Hi,
SS/TW or something else?
That STi IC won't fit your SS...unless you have a BFH to massage your firewall - a lot...search on here to double-check.
You need a stock SS BPV or the STi BPV? That will also be a challenge to make work on the SS as the throttle body setup is different and the STi was DBW. Most (all?) use the adapter plate and run a hose back to the intake and use the SS BPV.
FWIW, the '06-07 WRX and '06-08 FXT BPV will also work.
GL,
Td
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Naked Buell
Re: Bypass Valve
The 2.2T is in my Brat. I have upgraded to a TD04 and have added a sti aftermarket intercooler. I have the stock SS bypass valve and I can use that? If so, is there any pics so I can understand better what you mean about this adapter plate?
I am fuzzing about what hooks up where so any info and pics would be great. Thx
wtdash
Re: Bypass Valve
Post by wtdash »
MINE
Other Options
Td
p.s. HERE you can add a Sig to your Profile
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
