We started out needing to replace a torn drivers side steering rack bushing. We bought an OEM one for $25 and disassembly went quick. We wrestled with getting the new boot up and over the lip on the rack. Could not get it. We ended up heating up a pot of water to the point where it was simmering and put the boot in for a couple of minutes. Worked fabulous! It went up and over much easier. We anchored it with several zip ties connected to one another. Better idea for this?
While under there we found the same side CV axle had a tear at the hub. Rebuilt unit from NAPA with AAA discount was ~$71 including $12 core charge. Re-used the original roll pin and tapped in with a carpet tack punch (I bought one specifically for doing this very thing). Getting it all back together, we than notice the outer tie rod end oozing some grease....crap. Well, that will have to wait a day or two for NAPA to get one in. Alignment scheduled for this upcoming week. That's the news, reporting live from Minneapolis.
yesterdays suspension adventure
Re: yesterdays suspension adventure
The steering rack boots are held on with a little spring type band. The rubber lips fold over these. Did you see this on the old boot?
Here are pics from when I put new boots on my rack.
http://www.main.experiencetherave.com/s ... s/ej22t/21
If you have to replace the tie rod I wouldn't bother getting an alignment until after that work is done, unless you don't plan to replace that for a while.
We over stretched that spring band.
Ahh...that sucks
