				First gen rear suspension question. With photos!
				Posted: Sun Mar 30, 2014 10:31 pm
				by Sublimejoe
				I have a 1993 Legacy and I am trying to get all of the suspension in good working order so I can drive without fear of death. I figured out most of the front problems already but the rear is a different story. When I jack up the rear of the car I can move the wheel in and out a bit. It looks like I need a few bushings here:
After looking at this diagram I have determined that the part I need is number 7 for the front lateral link bushing. Is that correct?
What confuses me is that in my photo there seems to be a bushing on the knuckle, number 5 in the above diagram, but no bushing is listed. Do I have to buy the whole knuckle to replace that bushing? Is the knuckle called something else and causing my searches to be fruitless?
				Re: First gen rear suspension question. With photos!
				Posted: Sun Mar 30, 2014 10:41 pm
				by SILINC3R
				you may also have a bad wheel bearing. that is the normal test to see if it is bad.
				Posted: Sun Mar 30, 2014 10:45 pm
				by Sublimejoe
				SILINC3R wrote:you may also have a bad wheel bearing. that is the normal test to see if it is bad.
That also crossed my mind, because the way the wheel is moving seems like a bad wheel bearing to me. The thing is, that bushing also seems to be bad, so I was going to start with the cheaper option first and hope that corrects the issue.
				Posted: Sun Mar 30, 2014 11:12 pm
				by Sublimejoe
				According to this diagram, it looks like the bushing I need is #27, the rear trailing link bushing:
Thoughts?
				Posted: Mon Mar 31, 2014 1:26 am
				by rallyak
				Bushings aren't easy, and if you are going to replace them do them all. I bought mine from Ralli spec STI ones but I believe wheel bearing is cheaper and easier.
				Posted: Mon Mar 31, 2014 1:41 am
				by rallyak
				Also if you going to replace the bushings I would get lateral links to put a sway bar on, you won't be disappointed. Up grade Two in one shot.
				Posted: Mon Mar 31, 2014 2:07 am
				by Sublimejoe
				Yeah I am going to knock them all out at once. It's only $220 for all of the bushings for the rear and two that I haven't already bought for the front. Not bad for basically completely replenishing the suspension.
Care to share a link to the sway bar compatible lateral link?
				Posted: Mon Mar 31, 2014 4:22 am
				by rallyak
				Any 90-91 will work, but the better design is the second gen legacy outbacks. The end links design are better.
				Posted: Mon Mar 31, 2014 7:17 pm
				by jamal
				You can also go aftermarket with those. I have the turn in concepts poly bushings and really like them. They are a split bushing so you just push in each half by hand to install. They come in race and street hardness.
Pictures of mine here:
http://jamalb.net/gallery/v/98lgt/suspension/?g2_page=3
				Posted: Tue Apr 01, 2014 2:52 am
				I recommend going with the split poly bushings.  They are MUCH MUCH easier to install!
				Posted: Fri Apr 18, 2014 1:18 am
				by turboboxer92
				Where did u guys get those split bushings or did u get a set?
				Posted: Fri Apr 18, 2014 6:48 pm
				by jamal
				Mine are made by turn in concepts in ohio, you can get them there or from a dealer (like me for example). There are two versions, a race 95a graphite lubricated version and then a softer street 70a hardness. I have the race version, which gives a thunk from the rear similar to what you get from an alk in the front, plus a little extra tire noise.
				Posted: Tue Sep 02, 2014 3:38 pm
				by Azam8400
				jamal wrote:Mine are made by turn in concepts in ohio, you can get them there or from a dealer (like me for example). There are two versions, a race 95a graphite lubricated version and then a softer street 70a hardness. I have the race version, which gives a thunk from the rear similar to what you get from an alk in the front, plus a little extra tire noise.
Hello
How much for all both front and rear bushings? will you ship to Kuala Lumpur Malaysia.
Best Wishes
Rizal
