I racked my brain and figured this out!
Here is my custom crank pulley holder! I used two the the biggest bolts which hold the front seats down and did this! Worked like a charm!
Ultimate cheap crank pulley holder!
Re: Ultimate cheap crank pulley holder!
You sure like making threads
I always use a flat tip screwdriver in a access hole on the passenger side close to the head. It's a bolt hole that directly to the flywheel and a 4inch screwdriver is all you need.
Charles
That's a good idea I thinks.
haha, you can also look here.Splinter wrote:You sure like making threads
JATmotorsports.com they have all the special tools you should need.
Mmmm, more toolsSILINC3R wrote:JATmotorsports.com they have all the special tools you should need.
Wow thanks tony for that site. Ill be ordering tools and some other things one of these days from tyem. So much good stuff.SILINC3R wrote:haha, you can also look here.Splinter wrote:You sure like making threads
