Bog issue. 4psi- psi 2800 rpms - 3200rpm?
dillonr92
Post by dillonr92 »
So In my 92 turbo legacy. Since I put the td04 in I've had a bogging issue around 4 psi to 9psi. And around 2800 rpm to 3200rpm. After that range it hits 10+psi and little higher rpm then pulls great. I've checked to see if there is any leaks everything good there. it holds pressure and boosts no problem. But it Boggs hella in that rpm/psi range.. I'm stumped.
Sent from my SCH-I545 using Tapatalk
92 SS winestone red. td04 - FMIC. RWD 5 spd swap/LSD.dead...
94 LEGACY GT RAISED ROOF WAGON, fozzy lift hydro clutch/91SS 5speed/VLSD..#5.NEW FuLL DRiFT SLuT 93SS winestone,RS 5speed RWD. Welded rear, td04, fmic, 17x9 +20
Re: Bog issue. 4psi- psi 2800 rpms - 3200rpm?
Can you tell us a little more about your setup and how long has this been happening.
When you swapped in the TD04, did you also install the TMIC? Do you have a 90 degree silicone or rubber adapter on the turbo inlet?
wtdash
Post by wtdash »
Stock injectors correct?
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
