So I picked up some 04 STI struts and springs with less than 20k miles for around $400 for my 90 sedan.
I am reading that the rears might have some camber issues.. Is it unstreetable or just not "perfect?"
Would you guys recommend replacing anything else while doing the suspension?
STI suspension and camber?
Re: STI suspension and camber?
Should be fine I think. Get some camber bolts for the rear just in case. New brakes?
I just bolted mine right up and drove.
I'll just throw em on
Remember that this is 10 year old suspension... luckily they can be rebuilt for $$$.
rear camber bolts and you're set..
as far as mounting . you'll need to re-use your rear top mounts, or re-drill 1 hole and use the stock sti rear mounts
1994 SS "JDM-OEM"
1994 gt wagon, next build
1994 turbo wagon
1994 turbo wagon
Roger that.
