Steering wheels swap/ Clock spring removal
shoefean
Post by shoefean »
So i just got done swapping interiors to black and i picked up a 2nd gen black steering wheel. I know the airbag plugs wont match so how do you take the clock spring off of a 2nd gen? Will it plug and play with my first gen or will i have to mess with wiring?
Going from this:
To this:
Re: Steering wheels swap/ Clock spring removal
I don't have any experience with swapping the clock springs, but hopefully someone else will be able to help.
(Free bump)
Aeryck
Post by Aeryck »
looks like I have this issue. I just did my 82 Yota P-U but this is a lot more complicated. I am thinking of taking apart a junk-yard car first if I can't find any info
To the original poster, I just added the variable intermittent wiper stalk and have some pictures of the first gen Impreza clock spring (which should be same/similar to second gen Legacy). Not sure if they'll help, but here's the link.
http://main.experiencetherave.com/subar ... iperstalk/
oldscoobyturbo
Post by oldscoobyturbo »
from my experience if you get a clock spring from the newer car too you can re-pin the plug using the one for your car and it will work except for the airbag. I've modified a few newer momo wheels to work with the cruise control etc.
Silver 99 Legacy GT Wagon
White 90 BC5 RS Type RA
