Chads 92 SS
92legacyawdturbo
Chads 92 SS
Post by 92legacyawdturbo »
So first off head went out and could have just fixed the issue there but instead did a rebuild on the motor with different heads.
EJ22T block
Wiseco Forged Pistons (.020 Over)
Eagle Forged Rods
Arp Head Studs
Comectic Head Gaskets
10MM Oil Pump - New
Water Pump - New
Thermostat OEM
New Fuel Filter
New Spark Plug Wireset
Walbro 255 Fuel Pump
Gasket Set
TD-04 Turbo
Halman Manual Boost Controller
EJ20G headsEJ20G Intake Manifold
EJ20G Fuel Rails
EJ20G Injectors
Phenolic Thermal Manifold Spacer
Block of course was machined and heads milled as well.
Last edited by 92legacyawdturbo on Wed May 14, 2014 9:01 pm, edited 1 time in total.
1992 Awd Legacy Turbo Sedan
92legacyawdturbo
Re: Chads 92 SS
Teardown:
92legacyawdturbo
Re: Chads 92 SS
New Pistons and Rods:
92legacyawdturbo
Re: Chads 92 SS
Heads and Block sent off:
92legacyawdturbo
Re: Chads 92 SS
Reassembly:
Re: Chads 92 SS
Looks good Chad!
