E-Brake problems. please help!
92wagon
Post by 92wagon »
I put the new E-brake shoes on with new hardware ..... Now the new rotors won't fit over the new shoes... WTF. The E-brake is released and the adjuster is all the way closed as well. - BRAKE HATE COMMENCE.
What else could be going wrong here??? HELP!
92wagon
Re: E-Brake problems. please help!
Post by 92wagon »
Here are a few pictures of how it sits.... I added the original adjuster thinking that it may be shorter... It wasn't.
http://imgur.com/a/Rx7H2
rallyak
Post by rallyak »
Every thing looks good. Have you loosened the cable adjustment? It's under the console but looking at the pics it doesn't look tight.
Charles
92wagon
Post by 92wagon »
I have..
It may just be that those e-brake shoes are slightly larger than they should be.
Have you looked if there is a lip on the inside of the parking brake drum/rotor? That may be causing the rotor to go back on smoothly.
