So I picked up a rear dif from a 2001 rs to go in my 92 ss. Seems as though I need to get different axles, or there is also a way to use parts from both my stock 3.90 dif to use my current axles yes?
Explain as if I don't know anything, cuz quite honestly, I really don't.
4.11 LSD rear. axle help.
06 Obxt (Clam-jam daily)
92 SS (Forever broken)
92 240sx Vert (Shitbox money-pit drift project)
Re: 4.11 LSD rear. axle help.
This may help http://bbs.legacycentral.org/viewtopic.php?f=7&t=53266 I'm willing to bet LGT rear diff is the same and what you need is legacy outback axles.
Charles
Would it be cheaper to use parts from my stock dif and the new dif to make my current axles work?
