turbo info correct?
turbo970
turbo info correct?
Post by turbo970 »
http://legacycentral.org/library/turbo_faq.htm
how much of this it true and whats bs
Re: turbo info correct?
Without having to read the whole thing (I last read it when I joined the site lol), which parts are you wondering about?
turbo970
Post by turbo970 »
just the general info different sites have different info on the same type of cars
I'd say most of the info is correct. There may be some info that's slightly off, but overall it's pretty accurate. If you have something specific you're wondering about, just let us know.
turbo970
Post by turbo970 »
just trien to learn what i can about these cars. i found it weird tho that he said we can run our subies at 12 psi b4 a inter cooler is needed with proper fuel system but basically just wanna learn
Some of those things, particularly that is a little bit on the subjective side. While you may be able to do that, some people may recommend against it.
turbo970
Post by turbo970 »
thats why i want to ask you guys what was good info and whats iffy info. i even read on a turbo car web site that inter coolers arent needed til 300 plus hp
James614
Post by James614 »
The idea that you don't need an inter cooler until xx HP is ignoring so many variables that its misleading at best.
I'd suggest sticking to Subaru sites to learn the theory, at least when people give you technically incorrect information its still likely to be applicable to our cars.
Just use an intercooler!
turbo970
Post by turbo970 »
i know i know mike. just doing research on our cars and turbo cars in general is all. so many sites so many theories
