air ride removal
JohnP
air ride removal
Post by JohnP »
so I've been converting my 92 Legacy Wagon to coil springs opposed to a ride. I have removed one fuse in the engine compartment and one fuse under the dash.
However I'm still getting a flashing hi air ride switch next to the steering column what else needs to be removed it and where is it located.
I'm planning on removing the air compressor and would like to remove the air computer just don't know where its located. thank you in advance for your information.
rallyak
Re: air ride removal
Post by rallyak »
Compressor is located under drivers side fender. I sure removing the inter splash is all you need to access it to remove it. I left mine in and never removed it,I was lazy.
Charles
The air suspension computer is located under the driver's seat. You may be able to reach the plug through the flap in the carpet. This picture shows where.
http://www.surrealmirage.com/subaru/fil ... tion06.jpg
JohnP
Post by JohnP »
Josh maybe you link the wrong picture I don't see the ride height control unit
rallyak
Post by rallyak »
Diagram 67-3 to the right of the power window relay and breaker.
Charles
