Dashlights out!
danialraimes
Dashlights out!
Post by danialraimes »
Apologies if this has been asked before, but I can't find an answer anywhere.
I installed a new stereo deck and hooked up my lighting for my boost gauge, which in turn killed my dashlights and cigarette lighter.
I read that they're on the same circuit as the climate controls, but all of those have illumination behind them. All my fuses are fine.
Any ideas?
danialraimes
Re: Dashlights out!
Scrap this. Read that it's my illumination control module.
If anyone needs help finding or replacing this let me know, I will be a pro tonight haha
rallyak
Re: Dashlights out!
Post by rallyak »
Illumination control module is under the dash just right of HVAC controller. I need to replace mine also, if I tap my dash right where the controller is,it comes back on.
Charles
danialraimes
Re: Dashlights out!
I'm just about to put in the icu I got. It's from a 2nd gen as there was no first gen there but I'll see if it works still.
danialraimes
Re: Dashlights out!
Don't do what I did. Find a 1st gen haha. It doesn't work :(
Re: Dashlights out!
Just a note when hooking up your boost gauge lighting for illumination. The illumination circuit has a separate ground through the control module. So you must hook up both wires from the boost gauge lighting to the positive & negative going to the control module.
If you hook up the negative lead from the lighting to ground, it'll likely fry the control module.
danialraimes
Re: Dashlights out!
Thanks Josh. You're a wizard buddy, I've never seen any so dedicated to helping noobs out.
Re: Dashlights out!
Glad to help & you're welcome! :)
danialraimes
Re: Dashlights out!
I'm gonna try track down a first gen ICU this weekend. They're pretty rare in Canada but I've found a guy who's possibly parting out his wagon. (I want his TBE hehehe)
I learned today that canada was one of the only places with flatroof wagons, so I fell in love with those and now I want one...
Brisky
Re: Dashlights out!
Post by Brisky »
Hello,
I thinking I am having a similar problem on my car.
Dash lights will be on, drive for a bit and then without doing anything the entire dash will go out, but if I turn off my lights and turn them back on it will stay on and continue to go out intermittently.
Fuses look ok, and the lights always come back on when I switch them off and on again.
First are we talking about the Illumination Control Unit (ICU)?
A.) What is that?
B.) Where is that? (pics would be helpful)
C.) How do I replace it?
Thanks guys!
OK I found the diagram showing where it is on the passenger side facing the center console next to the glove box.
Do I need to take the glove box out or is it right there?
http://www.surrealmirage.com/subaru/fil ... tion05.jpg
Brian
2001 Legacy GT - Sedan - White - Manual
18inch TSW Wheels, Federal SS-595 Tires, Centriic Rotors, Stoptech Brake Pads, STi Exhaust, & Torque Solutions Shifter bushings
danialraimes
Re: Dashlights out!
You need to pull the glove box out but it's like 2 screws man. It's very simple, i pulled mine out with no issue.
Brisky
Re: Dashlights out!
Post by Brisky »
danialraimes wrote:You need to pull the glove box out but it's like 2 screws man. It's very simple, i pulled mine out with no issue.
Ok sweet.
I guess I will need to go by a junk yard and try to grab some.
Priced the part at subie general parts and was $75....
Brian
oldscoobyturbo
Re: Dashlights out!
Post by oldscoobyturbo »
post the part number I might have a couple of those from my part outs
Silver 99 Legacy GT Wagon
White 90 BC5 RS Type RA
danialraimes
Re: Dashlights out!
Scrap yards will sell them for $3. They think they're just relays.
Re: Dashlights out!
It's an actual control unit rather than just some relays.
