5 Speed Manual into Auto RHD AWD Legacy
Sublimejoe
Post by Sublimejoe »
The title pretty much says it all. I am looking to do this swap and I'm not having much luck finding info. I have seen a few other threads but nothing that is quite right.
I am interested in what parts I will need to do this swap. Since the car is already down anyway, and the motor is coming out, I figured it might be the time to do this too.
Thank you everyone in advance for your help!
Parts Needed:
Manual Cluster
Front & Rear bumper Chrome Trim
mjc1310
Re: 5 Speed Manual into Auto RHD AWD Legacy
Post by mjc1310 »
I'm not sure of the differences that might come from this being a RHD, but check the stickies before you hit the search box.
Here's a link to the drivetrain section stickies. Josh has compiled a full write-up on the swap from parts needed to pictures. Hope this helps.
http://bbs.legacycentral.org/viewtopic.php?f=7&t=36800
Sublimejoe
I actually did see that thread, but after digging thru his page I don't see anywhere if the car was auto to begin with or not. I see he bought a pedal set from a turbo car, but it doesn't say whether that was because it was needed or if its an upgrade. He did mention that a lot of parts were upgraded.
Parts Needed:
Manual Cluster
I responded to your other thread: RHD and LHD pedal boxes are different. Turbo pedals aren't special, but you want to get some from a RHD car that came with a hydraulic clutch (eg. all turbos, and certain non-turbos).
OR, if you plan to stay N/A, you could potentially run a cable clutch tranny like all usdm ej18's and ej22 na's ran. But the likelyhood of someone importing an n/a RHD subaru front clip with a cable clutch-based pedalset are virtually nil, hence my suggesting the hydraulic set. The cable clutch and hydraulic clutch pedal sets are not interchangeable either.
Sublimejoe
So can I essentially get a rhd pedal box from basically any Subaru or are they different for each model & year?
Parts Needed:
Manual Cluster
There are differences between years, but 1st gen legacy and impreza fit for sure. That's what I've personally seen installed.
Sublimejoe
Awesome, just asked a friend in New Zealand to try and find me one. What other parts (if any) are RHD specific?
Parts Needed:
Manual Cluster
beaconhillkilla
Post by beaconhillkilla »
If I were to take a guess I would say that you could probably use a set of pedals from any 93-07 impreza or WRX (so long as they're from both a RHD car and they're for a wet clutch). I used a set of pedals from an 06 WRX when I did my auto to manual swap.
1992 Legacy SS - Auto to 5MT swap and too much of my free time.
Sublimejoe
Ive been doing a lot of poking around on ye' olde internet, what is stopping me from just using this:
http://www.jegs.com/i/Wilwood/950/340-1 ... oCqBLw_wcB
Parts Needed:
Manual Cluster
Not sure how that would mate up to the stock components, but if you're modifying things it may just be some additional modifications.
mx4life
Post by mx4life »
What year legacy? I just did my swap so maybe I can help ya out with info
Click For My 93
Click For My RHD 97
'93 SS V3 RA/STi EJ20K 4.44 DCCD
'97 RHD Wagon soon to be TT
Sublimejoe
awesome! Mine is a 1993
Parts Needed:
Manual Cluster
Chrisg03
Post by Chrisg03 »
i did the swap as well surreal image's diagrams and wiring works on them as well and the first time i did it i cut and welded two pedal boxes together to make the pedal box work with the cable clutch and you have to make a hole in the firewall for the cable to make sure its not kinked but i later got a hydraulic set from a JDM model
Always open to learn
Sublimejoe
Oh nice, and yours is rhd as well?
I purchased an ej22 and five speed tranny from a 1996 impreza. I'm pretty sure that's still a cable tranny right?
Parts Needed:
Manual Cluster
Chrisg03
Post by Chrisg03 »
Yes its a RHD wagon as well i used an EJ25D from a 97 outback and the tranny from a 96 impreza brighton it should be a cable clutch tranny but it does have the bolts to install a clutch slave but it must be a push type clutch
Sublimejoe
Oh great! Where did you find your pedal set? I found a couple on ebay New Zealand but many people over there are non responsive. Sucks.
Parts Needed:
Manual Cluster
Sublimejoe
Parts Needed:
Manual Cluster
Chrisg03
Post by Chrisg03 »
that should work just fine you would probably have to fiddle abit with the brake light switch and whatnot
Sublimejoe
Close enough for me! Hopefully he actually writes me back haha
Parts Needed:
Manual Cluster
mx4life
Post by mx4life »
Same pedal I got.
Click For My 93
Click For My RHD 97
mx4life
Post by mx4life »
Let us know when you get the pedals in! If you need help with the wiring let me know ill post pictures of mine. One of the most important is jumping the neutral safety switch.
Click For My 93
Click For My RHD 97
mx4life wrote:One of the most important is jumping the neutral safety switch.
Are you talking about pins 11 & 12 on the AT trans connector? The neutral safety switch really doesn't have much bearing on what the ECU does when it's configured for a MT.
mx4life
Post by mx4life »
Yeah that's what I meant.
Click For My 93
Click For My RHD 97
Sublimejoe
So a guy on here is selling a pedal set from his 91 non-turbo Legacy. I know its not exactly what I would need, but is this something I can even work with?
Parts Needed:
Manual Cluster
Is it RHD?
