Page 1 of 2
5 Speed Manual into Auto RHD AWD Legacy
Posted: Wed Jul 23, 2014 3:14 pm
by Sublimejoe
The title pretty much says it all. I am looking to do this swap and I'm not having much luck finding info. I have seen a few other threads but nothing that is quite right.
I am interested in what parts I will need to do this swap. Since the car is already down anyway, and the motor is coming out, I figured it might be the time to do this too.
Thank you everyone in advance for your help!
Re: 5 Speed Manual into Auto RHD AWD Legacy
Posted: Wed Jul 23, 2014 4:13 pm
by mjc1310
I'm not sure of the differences that might come from this being a RHD, but check the stickies before you hit the search box.
Here's a link to the drivetrain section stickies. Josh has compiled a full write-up on the swap from parts needed to pictures. Hope this helps.
http://bbs.legacycentral.org/viewtopic.php?f=7&t=36800
Posted: Wed Jul 23, 2014 4:36 pm
by Sublimejoe
I actually did see that thread, but after digging thru his page I don't see anywhere if the car was auto to begin with or not. I see he bought a pedal set from a turbo car, but it doesn't say whether that was because it was needed or if its an upgrade. He did mention that a lot of parts were upgraded.
Posted: Thu Jul 24, 2014 6:13 am
by mike-tracy
I responded to your other thread: RHD and LHD pedal boxes are different. Turbo pedals aren't special, but you want to get some from a RHD car that came with a hydraulic clutch (eg. all turbos, and certain non-turbos).
OR, if you plan to stay N/A, you could potentially run a cable clutch tranny like all usdm ej18's and ej22 na's ran. But the likelyhood of someone importing an n/a RHD subaru front clip with a cable clutch-based pedalset are virtually nil, hence my suggesting the hydraulic set. The cable clutch and hydraulic clutch pedal sets are not interchangeable either.
Posted: Tue Aug 19, 2014 2:31 am
by Sublimejoe
So can I essentially get a rhd pedal box from basically any Subaru or are they different for each model & year?
Posted: Tue Aug 19, 2014 3:18 am
by mike-tracy
There are differences between years, but 1st gen legacy and impreza fit for sure. That's what I've personally seen installed.
Posted: Wed Aug 20, 2014 4:47 pm
by Sublimejoe
Awesome, just asked a friend in New Zealand to try and find me one. What other parts (if any) are RHD specific?
Posted: Wed Sep 10, 2014 4:49 am
by beaconhillkilla
If I were to take a guess I would say that you could probably use a set of pedals from any 93-07 impreza or WRX (so long as they're from both a RHD car and they're for a wet clutch). I used a set of pedals from an 06 WRX when I did my auto to manual swap.
Posted: Tue Nov 04, 2014 9:49 pm
by Sublimejoe
Ive been doing a lot of poking around on ye' olde internet, what is stopping me from just using this:
http://www.jegs.com/i/Wilwood/950/340-1 ... oCqBLw_wcB
Posted: Tue Nov 04, 2014 10:46 pm
Not sure how that would mate up to the stock components, but if you're modifying things it may just be some additional modifications.
Posted: Fri Dec 19, 2014 10:15 pm
by mx4life
What year legacy? I just did my swap so maybe I can help ya out with info
Posted: Sat Dec 20, 2014 1:33 am
by Sublimejoe
awesome! Mine is a 1993
Posted: Sat Dec 20, 2014 2:56 am
by Chrisg03
i did the swap as well surreal image's diagrams and wiring works on them as well and the first time i did it i cut and welded two pedal boxes together to make the pedal box work with the cable clutch and you have to make a hole in the firewall for the cable to make sure its not kinked but i later got a hydraulic set from a JDM model
Posted: Sat Dec 20, 2014 2:59 am
by Sublimejoe
Oh nice, and yours is rhd as well?
I purchased an ej22 and five speed tranny from a 1996 impreza. I'm pretty sure that's still a cable tranny right?
Posted: Sat Dec 20, 2014 8:11 pm
by Chrisg03
Yes its a RHD wagon as well i used an EJ25D from a 97 outback and the tranny from a 96 impreza brighton it should be a cable clutch tranny but it does have the bolts to install a clutch slave but it must be a push type clutch
Posted: Sat Dec 20, 2014 8:24 pm
by Sublimejoe
Oh great! Where did you find your pedal set? I found a couple on ebay New Zealand but many people over there are non responsive. Sucks.
Posted: Sat Dec 20, 2014 8:33 pm
by Sublimejoe
Posted: Sun Dec 21, 2014 3:21 am
by Chrisg03
that should work just fine you would probably have to fiddle abit with the brake light switch and whatnot
Posted: Sun Dec 21, 2014 5:27 am
by Sublimejoe
Close enough for me! Hopefully he actually writes me back haha
Posted: Sun Dec 21, 2014 5:34 am
by mx4life
Same pedal I got.
Posted: Sun Dec 21, 2014 7:19 am
by mx4life
Let us know when you get the pedals in! If you need help with the wiring let me know ill post pictures of mine. One of the most important is jumping the neutral safety switch.
Posted: Sun Dec 21, 2014 9:02 pm
mx4life wrote:One of the most important is jumping the neutral safety switch.
Are you talking about pins 11 & 12 on the AT trans connector? The neutral safety switch really doesn't have much bearing on what the ECU does when it's configured for a MT.
Posted: Sun Dec 21, 2014 9:03 pm
by mx4life
Yeah that's what I meant.
Posted: Mon Dec 29, 2014 6:50 pm
by Sublimejoe
So a guy on here is selling a pedal set from his 91 non-turbo Legacy. I know its not exactly what I would need, but is this something I can even work with?
Posted: Mon Dec 29, 2014 6:51 pm
by mike-tracy
Is it RHD?
