BC Racing ER Series
BC Racing ER Series
I just purchased a '90 Legacy wagon. I have a set of BC ER series coilovers on my old 2007 WRX (not running) right now. It would be a shame to let them go to waste and I was thinking of swapping them over. From what I've read in the suspension sticky and elsewhere on this forum, they should fit. I just want to double-check before I go tearing things apart. Both the bolt pattern for the top mounts and the bolt locations in the knuckle are the same, correct? Everything should fit perfectly? Does the Legacy come stock with front camber bolts as my WRX did?
Re: BC Racing ER Series
Front stut bolt pattern is the same, rear isnt. You could drill the rears...
Redrill the rear or purchase gc impreza top mounts. Yes your legacy does have camber bolts up front same as the wrx, you'll find many things familiar while working on the legacy, basic suspension design was pretty much the same. Just minor differences.
Fronts are the same bolt pattern but clocked differently.
