legacy 93 start & dies
legacy93sey
Post by legacy93sey »
my legacy keeps dying each time i start it sometimes it might take longer for it to die,there are no check engine.dont know whats wrong????somebody help me plzzzzzzz
rallyak
Re: legacy 93 start & dies
Post by rallyak »
You need to pull the codes, I suspect the MAF sensor is bad. You can test it by unplugging it and see if it stays running, but the car will run real rich.
Charles
legacy93sey
pulling the codes means connecting the green connector right???thanks mate i will try wat u said :)
rallyak
Post by rallyak »
Use the black ones to pull codes.
Here's a link from Josh's site:
http://www.surrealmirage.com/subaru/eng ... l#resetecu
Charles
legacy93sey
thank you so much :),im getting the code 23,which means their is a problem with my maf sensor??
rallyak
Post by rallyak »
No problem.
Charles
Yes, 23 is the MAF sensor and that seems to match up with your symptoms. See if you can find a used replacement MAF sensor.
