Stock and only hitting 5psi......Where to look?
GTEASER
Post by GTEASER »
Hey guys!!! First I want to say that this board is AWESOME!!!
Before I get any "do a search" comments, I have done a search, many searches, and I have been doing lots of reading, but there is a lot to process, especially with a car I am not yet familiar with. I just got my completely stock '92 SS last week and the learning curve is very steep. The car has 158k miles on it and is in pretty good condition overall and looks well taken care of throughout its life. The car runs very well, so I figured it would a good idea to get a boost gauge right away to make sure the turbo is performing properly and I am hitting stock target boost before I start with any mods such as an intercooler, the Apexi intake, or exhaust.
So I picked up a mechanical Autometer SportComp boost gauge and installed it last night. It only came with a Tee for 1/8" vac lines so I was relegated to installing it on the vac line that comes off the Cylinder 1 intake runner near the charcoal canister. I would have preferred putting it on the reference vac line going to the BPV, but that is 1/4" hose. I have ordered a 1/4" tee and it should be here by the end of the week.
At idle vac is a solid 21 in/hg and on decal in gear it drops to 25 in/hg. With moderate throttle input it quickly comes out of vac and climbs to 0 psi, but at WOT it won't seem to hit anything more than 4-5 psi of boost.
Now the interesting part, and something I was only able to verify with the boost gauge........as soon as I get into positive boost pressure, a whistling sound starts coming from under the hood. It increases a little louder with more throttle input but really stays very constant as long as I am in boost.
So it would appear that I have a boost leak somewhere after the compressor, or... the wastegate or BPV are not working properly. Any other ideas? And is there a diagram somewhere on this board so that I can be certain that I have checked all vac lines and connections? Is there a good way to test the wastegate and BPV?
Thanks in advance!!!
Re: Stock and only hitting 5psi......Where to look?
Here's the vacuum hose reference.
http://bbs.legacycentral.org/viewtopic.php?f=1&t=15268
When our Turbo Legacys are pushing 5 psi, it usually means the car is in limp mode. Do you have a check engine light? If so I would pull the codes and start there. It does sound like you have a boost leak. With the car idling I would spray all the pcv and vacuum hoses with starter fluid to see if the idle increases. If the idle does increase, it's a good indicator of a leak.
subaru_styles
Post by subaru_styles »
had the 5psi problem with my car for MONTHS with no cel light. tried new knock sensor, plugs, wires, coilpack, n didnt fix it.......
.even though there was no fault code for it, cleaned my maf. instanly back to normal
1994 SS "JDM-OEM"
1994 gt wagon, next build
1994 turbo wagon
GTEASER
Post by GTEASER »
Thanks guys!! No CEL. I will try the starter fluid trick and also clean the MAF and report back. I printed out the vac diagram as well as the PCV diagram.
Use MAF cleaner on the MAF. It doesn't leave a residue like brake parts cleaner would.
GTEASER
Post by GTEASER »
cj91legss wrote:Use MAF cleaner on the MAF. It doesn't leave a residue like brake parts cleaner would.
Yep, thank you, gonna pick some up after my meeting tonight. I will clean the MAF and reset the ECU and see what happens on the way to work in the morning.
The other thing to mention is that in partial boost you can sometimes hear the turbo noise which kind of sounds like a fluttering. Does the noise you hear sound like a whistle or something slightly different?
GTEASER
Post by GTEASER »
A whistle. I will be getting to this later today. Will update.
GTEASER
Post by GTEASER »
That was it guys! Thanks so much subaru_styles! The MAF was visibly dirty and it took a lot of squirts of the MAF cleaner to get the black gunk off of it. Shiny clean wires now. I disconnected the battery to reset the ECU so it can relearn. I'm hitting 8 psi now and the car pulls much harder in the lower rpm's, and runs noticeably smoother all around.
Glad to hear you got it fixed.
subaru_styles
GTEASER wrote:That was it guys! Thanks so much subaru_styles! The MAF was visibly dirty and it took a lot of squirts of the MAF cleaner to get the black gunk off of it. Shiny clean wires now. I disconnected the battery to reset the ECU so it can relearn. I'm hitting 8 psi now and the car pulls much harder in the lower rpm's, and runs noticeably smoother all around. Image
8)
1994 SS "JDM-OEM"
1994 turbo wagon
