limited to 9 psi
turbo970
limited to 9 psi
Post by turbo970 »
well now my subie will only boost to 9 psi. had a boost leak test today and they found no leaks then they put it in drive and held the brakes to make a load and they said its hissing at the actuator. so if it's truely bad would this work.
http://www.ebay.com/itm/Turbo-Wastegate ... 56&vxp=mtr
Re: limited to 9 psi
Which turbo do you have installed on your car? What are you using to control boost?
How much boost were you making before your problems occur.
turbo970
Post by turbo970 »
i was at 12 psi and i have a jdm tdo4. it still drives fine just cant get past 9lbs of boost. he said this morning to get a re enforced coupler between the in and throttle body
Do you have any codes stored in the ECU?
Are you using the stock boost control, manual boost controller, or aftermarket electronic boost controller?
turbo970
Post by turbo970 »
no codes and a grimmspeed mbc. it just happened suddenly. the coupler thats there now balloons out under boost so they say
Which coupler?
If it's ballooning under boost, it may also be leaking under boost.
turbo970
Post by turbo970 »
inbetween the tmic and the throttle body. i changed that to day and still only 9 psi and slowly drops the longer i hold the throttle. i'm also getting the wastegate fllutter noise when i power brake. going to try to adjust the actuator arm tomorrow. then going to replace the waste gate actuator its self if the adjustment doesnt help
turbo970
Post by turbo970 »
i adjusted the actuator rod and the power came back. but should i get a new actuator just to be safe?
How much did you adjust it? Was it loose before?
turbo970
Post by turbo970 »
i turned it like 7 turns. and it was fine when it was first installed
I'd probably wait and see if that fixes things or if you need to turn it again sometime in the future.
turbo970
Post by turbo970 »
its holding 12 psi now so i'll wait
