Transmission code for ATF Temp
kahunaking
So I went through the TCU codes and I have the code for an ATF Temp sensor issue. Has anyone had a similar problem or no, I just bought the car and I am trying to fix things on it one by one and this is the next issue.
Re: Transmission code for ATF Temp
Have you tried resetting the TCU to see if the code comes back. Are you having any abnormal driving conditions?
kahunaking
No abnormal driving conditions.
Then I would try resetting the TCU and see if the code comes back.
kahunaking
Reset the TCU and now that the engine is making power it is running in FWD mode for sure. Still pulling the ATF Temp code, I am picking up a multimeter tomorrow to check the wiring/resistance of it.
Ok, let us know what you find.
