msd ignition controller
bcmaxx
Post by bcmaxx »
Just thinking about a msd 2 controller on my 22na turbo swap. They list a timing controller on the site for use with the box. Will this work on my sube to retard timing a bit?
http://www.msdperformance.com/Products/ ... ntrol.aspx
Re: msd ignition controller
In reviewing the instructions, I'm not so sure this will work with the stock ECU.
http://www.msdperformance.com/WorkArea/ ... 5032386409
bcmaxx
Post by bcmaxx »
Legacy777 wrote:In reviewing the instructions, I'm not so sure this will work with the stock ECU.
I have a mallory hyfire6 to try. The boost retard is integrated in the box. Just add a map sensor. Hoping i can get this wired up. If i do ill post up. My jobber supplier said i can return if the setup wont work
Cool. Yeah, let us know if it works.
bcmaxx
Post by bcmaxx »
Legacy777 wrote:Cool. Yeah, let us know if it works.
no go, had to return it, only has one coil trigger.....
Ok, well at least we know now.
bcmaxx
Post by bcmaxx »
Legacy777 wrote:Ok, well at least we know now.
yes , there was only one way to find out! looks like i'll be staying stock, the dis2 is out of my price range for now. actually itys almost as much as my entire build
