radiator fitment issue
Posted: Mon Oct 27, 2014 10:58 pm
by silver03
The plastic end tank on our OEM 94 Legacy L wagon radiator has recently developed a couple of pin hole leaks. The car is a 5MT. Are there any fitment issues if I put one in from a 4eat car? thanks
Re: radiator fitment issue
Posted: Tue Oct 28, 2014 12:34 am
by rallyak
It's fits no problem, just cap off the transmission lines. I've seen the cooler get corroded and eventually fail and coolant will leak out.
Posted: Tue Oct 28, 2014 1:45 am
by major_tom
rallyak wrote:It's fits no problem, just cap off the transmission lines.
This. The two lines in question will be poking out of the end of the radiator opposite the expansion tank. Mine came capped with rubber when I bought it new; perhaps the board has a recommendation on capping technique/materials?
Posted: Thu Oct 30, 2014 5:46 pm
Plain old rubber caps work fine. That's what I've got on mine.
Posted: Mon Nov 03, 2014 4:43 pm
by thewaterboy
Legacy777 wrote:Plain old rubber caps work fine. That's what I've got on mine.
Been running mine the same way for a few weeks now. Zero issues to report.
