radiator fitment issue
silver03
Post by silver03 »
The plastic end tank on our OEM 94 Legacy L wagon radiator has recently developed a couple of pin hole leaks. The car is a 5MT. Are there any fitment issues if I put one in from a 4eat car? thanks
rallyak
Re: radiator fitment issue
Post by rallyak »
It's fits no problem, just cap off the transmission lines. I've seen the cooler get corroded and eventually fail and coolant will leak out.
Charles
major_tom
Post by major_tom »
rallyak wrote:It's fits no problem, just cap off the transmission lines.
This. The two lines in question will be poking out of the end of the radiator opposite the expansion tank. Mine came capped with rubber when I bought it new; perhaps the board has a recommendation on capping technique/materials?
'92 L Wagon "the Yeti" - 295k mi and still running!
Turbo wheels n' Pirelli P6s / KYB GR2s / EBC Greenstuff pads + rotors / Walbro 255 / Apex'i airbox filter
Plain old rubber caps work fine. That's what I've got on mine.
thewaterboy
Post by thewaterboy »
Legacy777 wrote:Plain old rubber caps work fine. That's what I've got on mine.
Been running mine the same way for a few weeks now. Zero issues to report.
