Trouble fitting STI 5x100's
subieslayin
Post by subieslayin »
Hey guys! I have a 93 legacy sport sedan, and i recently purchased 04 sti bbs wheels for it. But when i went to put them on, the inside of the tire would rub on the strut.? is this normal? Do i need wheel spacers? Tire size is 225/45/r17
Thanks in advance!
James614
Re: Trouble fitting STI 5x100's
Post by James614 »
If I recall stock size for the STI is 225/40, yeah you probably need spacers or to go with a slightly smaller tire.
Welcome to the BBS.
Is it hitting the strut tower perch or the side of the strut body? If it's the strut body, a spacer or different size tire would be what you need to do.
jamal
Vendor
Vendor
Post by jamal »
225/45 is stock size. Yeah it can be close, especially with older struts. The wrx/sti moved the lower spring perches up to give more clearance. There is not really any extra thread on the wheel studs for much of a spacer, but you might be able to get enough room with a hammer by putting a dent in the perch where it rubs.
speezly
Post by speezly »
Speaking of spacers, anyone ever use the cheap 5mm ones from autozone or the like?
93 Legacy l AWD 5mt
87 GL-10 Turbo 5mt
