center diff squeeling
bcmaxx
Post by bcmaxx »
as titled , my center diff shreeks/squeels very loudly when making a sharp corner or turn under load. It did this before I replaced the center diff clutches and solenoid, and is still doing it. I've tried a fluid swap, added some leubeguard and still the same. It doesnt bind at all. and the rear gets plenty of power, awd works great, even under high boost. Any ideas?
I'm not too worried, because |I am on the hunt for a new 4eat, but until then....
Re: center diff squeeling
Hmmm that's very strange....I've never heard of the clutch packs making noise. If you put the gear selector in 1 and turn in sharp circles is it louder than if you just had it in D?
If you put a fuse in the FWD fuse holder does the noise go away?
