1991 ss td04 swap, need some insight
Front, Top, Air, Water.
1994leggy
Post by 1994leggy »
hey guys, found a 91 ss for cheep and now that i have the motor running id like to do a td04 and tmic swap, i got a free 05 fxt intercooler, and am going to buy the td04 in the next few days, does anyone have photos of hooking up the bpv and everything else other than the main y pipe, thanks!
Re: 1991 ss td04 swap, need some insight
Welcome to the BBS.
Have you looked at the sticky thread in this forum? It may not be exactly the components you have, but should be similar. I'm sure there are other threads with pictures and would recommend searching to see what you can find. Hopefully others that have used those specific components can chime in with more details.
http://bbs.legacycentral.org/viewtopic.php?f=3&t=38598
MConte05
Post by MConte05 »
Also plan on some engine management. Look into the RobTune.
