I bought it back in July, after having it for a couple weeks I started to work on things that needed attention. Most of the vacuum lines were connected wrong, a wheel bearing was completely gone, and other little things also got accounted for and fixed like the thermostat, ignition coil, axle seals. I also had to do sway bar links on the front, a tie rod end, and 4 wheel alignment.
The car sits on 4 brand new all season tires with aftermarket rims that I have no idea the name of but they look pretty cool. I have made two trips to Lake Tahoe (1000 miles both ways) this winter and the car does fine! What the car doesn't do properly is idle......Every sensor has been tested, checked, adjusted. No CEL, and everything MAF, IACV, KS, TPS, CTS, 02 sensor had a professional test and check.
Im in no hurry to sell but if there is a serious buyer out there I am looking to sell it for $2500.00
MODS
+ 3" Turbo BK Exhaust w/ Flow Master Muffler/sounds very deep and throaty.
+ TD04 w/ no shaft play, clean and in good condition.
+ 06 WRX TMIC/good shape, y pipe is put together/modded well no leaks.
+ Walbro 255 pump.
+ PLX Wide Band
+ Turbo XS BPV H34/Brand new a month ago.
+ WRX Seats front and back
+03 WRX Front and rear struts.
+ Tein S-Tech Springs ( lowered about 1.5")
Here is some older pics. I will get some newer ones soon.............................................................
I love this car but i have to start putting my money toward a truck. Im open to answer any questions and I check the forum all the time. If you want to PM me that's fine too.
