fuel tank swap
madmallard
fuel tank swap
Didn't know what section to put this in... i have a 90 wagon with a shot fuel tank, am i limited to just another of the same wagon body/chassis for a donor?
Re: fuel tank swap
As long as if you have a AWD, the donor is AWD. Can not mix 2wd with 4wd. But wagon or sedan are the same.
PRT motorsport Rally Team
Re: fuel tank swap
There are some gotcha's that others have detailed when swapping to other model tanks. Do a search for that if you like.
I'm 100% positive the 2000+ legacy tank won't fit, it is shaped differently and has different mounting points. A shame, cause that tank has one more gallon capacity.
