Moderators: Helpinators , Moderators
imtb
Posts: 51 Joined: Sat Jan 17, 2015 3:04 pm
Post
by imtb » Sat Jan 24, 2015 3:55 am
Just got this in and I do not have CEL hooked up, I am super stoked, to able to see any codes. I have 92 ej22 in my VW Synco.
Oxy Code
Posts: 27934 Joined: Tue Oct 15, 2002 11:37 am
Post
by Legacy777 » Sat Jan 24, 2015 9:05 pm
Do you have the oxygen sensor hooked up? If you do, I would check the wiring from the oxygen sensor to the ECU.
Try clearing the codes and see if the O2 sensor comes back.
imtb
Post
by imtb » Sun Jan 25, 2015 4:00 pm
O2 is hooked up, but I didnt try clearing the codes. I oreded a new one since this one is pretty gummed up.
I gues the ecu just runs in defualt mode since O2 not working? Maybe this is why plugs so clean.
Post
by Legacy777 » Sun Jan 25, 2015 11:47 pm
The O2 sensor is responsible for closed loop running and affects fuel trims which can increase power and/or improve fuel economy over time, depending on how you drive fuel type/quality, etc.
If the O2 sensor isn't work, the ECU stays in open loop mode and performs fueling via the fuel tables.
imtb
Post
by imtb » Fri Feb 06, 2015 4:19 am
Should I have the green connectors and the black connectors together when i use thiis?
I
Posts: 5000 Joined: Tue Aug 25, 2009 7:52 am
Post
by mike-tracy » Fri Feb 06, 2015 4:50 am
I used different software (Revscan) but I didn't need to plug the black or green connectors in to read values or reset codes.
Josh Colombo wrote: ↑ Mon Jan 14, 2002 10:23 am
Wait....I'm confused now.
Post
by Legacy777 » Sun Feb 08, 2015 11:33 pm
No, you don't need to have the diagnostic connectors when you use the scan tool.
