2 port AOS
turbo970
2 port AOS
Post by turbo970 »
can i hook up to this area for my 2 port AOS ?
turbo970
Re: 2 port AOS
Post by turbo970 »
i figured it out with the help of their tech support. i need to do some re routing but works great
bcmaxx
Re: 2 port AOS
Post by bcmaxx »
turbo970 wrote:i figured it out with the help of their tech support. i need to do some re routing but works great
What a neat idea. Id like to know how effective this is. Wouldnt crankcase vapour and pressure disturb the flow in and out?
turbo970
Re: 2 port AOS
Post by turbo970 »
it goes from the pvc to the aos then t's to the vent tube on the drivers side and t's again to the f pipe to the passenger side vent tube. then they said to cap off a line to the turbo intake like you would on a wrx.
James614
Re: 2 port AOS
Post by James614 »
That's the same style as the one Grimmspeed uses. I wouldn't mind trying one out, but not for anything close to the money GS wants for one.
turbo970
Re: 2 port AOS
Post by turbo970 »
this was 175 shipped and only a 2 port but seems to work well. only thing i notice is my a/f ratio gauge doesnt start going to the the green til like 10 psi of boost. dunno if thats good or bad
bcmaxx
Re: 2 port AOS
Post by bcmaxx »
turbo970 wrote:this was 175 shipped and only a 2 port but seems to work well. only thing i notice is my a/f ratio gauge doesnt start going to the the green til like 10 psi of boost. dunno if thats good or bad
If its a narrow band id seriously upgrade. You could be unknowingly doing damage. Even the autometer ones that look wideband arent
turbo970
Re: 2 port AOS
Post by turbo970 »
its a wide band. i really gotta get on it b4 things richen up. b4 the aos i could be at 8 psi and would be reading 12.3 on my a/f gauge. now anything under 10 lbs of boost it reads 14.6 or so 10 lbs or more things drop to 12.3 and lower
Re: 2 port AOS
Can you draw a diagram on how they recommended hooking it up? I am unable to follow the hoses.
turbo970
Re: 2 port AOS
Post by turbo970 »
it goes pvc to aos then aos to T 1 which connects to the driver side vent tube and connects T2 which goes to the F pipe and passenger side vent then capped off on the coffee cup mod
Re: 2 port AOS
A picture in this case is still worth a thousand words ;)
I'll have to go back and look at the pictures more closely.
turbo970
Re: 2 port AOS
Post by turbo970 »
i still have to re route the hoses . but thats how they said to hook it up. seems to help no oil in my air intake and the car seems a touch more responsive
turbo970
Re: 2 port AOS
Post by turbo970 »
well i've had this set up on for a while know and it seems to work well. i've even gained 10 miles per tank of gas.
