axle won't fit in diff
93FrostWhite
Post by 93FrostWhite »
Put in a va1ref-xg and can't get the axles to fit axles from a 97 legacy
Re: axle won't fit in diff
In what way won't they fit? Does the stub not fit into the diff or is it too long, etc? What vehicle did you swap in this diff from? What vehicle did the diff go into? Any more information you can provide would be helpful.
93FrostWhite
Stub won't go in diff like it's wrong spline or something I Don't k ow what the diff came off of bought it with a trans and axles from a guy that parts Subaru going into a 93 legacy
93FrostWhite
trans code tz102za5aa-gn
93FrostWhite
I think it might be a 22 spline diff going to pick up some impreza 22 spline axles and see if they fit can't really think of anything else
Yeah, I'd try different axles. The 93 Diff is supposed to have axle stubs in them. I don't know if the newer axles with male stubs are interchangable or not.
86BRATMAN
Post by 86BRATMAN »
Can you post a picture of the differential, if by chance it's from an impreza it could be one of two types of diffs it could be. Each takes its own specific axle type. I can easily id them on sight. But as long as they axles and diff match there is no reason they shouldn't fit together and swap into a first gen.
86BRATMAN
Post by 86BRATMAN »
I just checked through my fsms, you do in fact have an impreza rear diff, 4.11 ratio, v-type instead of the r160 legacy type diff. You will need impreza rear axles specific to the v-type diff.
