axle won't fit in diff
Posted: Wed Feb 11, 2015 4:41 pm
by 93FrostWhite
Put in a va1ref-xg and can't get the axles to fit axles from a 97 legacy
Re: axle won't fit in diff
Posted: Wed Feb 11, 2015 6:59 pm
In what way won't they fit? Does the stub not fit into the diff or is it too long, etc? What vehicle did you swap in this diff from? What vehicle did the diff go into? Any more information you can provide would be helpful.
Posted: Wed Feb 11, 2015 7:20 pm
by 93FrostWhite
Stub won't go in diff like it's wrong spline or something I Don't k ow what the diff came off of bought it with a trans and axles from a guy that parts Subaru going into a 93 legacy
Posted: Wed Feb 11, 2015 7:51 pm
by 93FrostWhite
trans code tz102za5aa-gn
Posted: Sun Feb 15, 2015 5:01 pm
by 93FrostWhite
I think it might be a 22 spline diff going to pick up some impreza 22 spline axles and see if they fit can't really think of anything else
Posted: Sun Feb 15, 2015 8:22 pm
Yeah, I'd try different axles. The 93 Diff is supposed to have axle stubs in them. I don't know if the newer axles with male stubs are interchangable or not.
Posted: Mon Feb 16, 2015 12:26 am
by 86BRATMAN
Can you post a picture of the differential, if by chance it's from an impreza it could be one of two types of diffs it could be. Each takes its own specific axle type. I can easily id them on sight. But as long as they axles and diff match there is no reason they shouldn't fit together and swap into a first gen.
Posted: Mon Feb 16, 2015 12:39 am
by 86BRATMAN
I just checked through my fsms, you do in fact have an impreza rear diff, 4.11 ratio, v-type instead of the r160 legacy type diff. You will need impreza rear axles specific to the v-type diff.
