Intake Tube
imtb
Intake Tube
Post by imtb »
Here is been my latest project. I picked up an extra intake tube and cut off the end to eliminate the curve. Not much differnce, jury still out. You call also see the heat sheild I made under the intake filter. It was sucking up hot exhaust and the sheild work very good. Just need to finish the other side to cover muffler. The cavity where the air filter is going has a fresh air snorkel going up the side of the van.
Revised. Kind of straight wantted a nice curve.
Orginal
Re: Intake Tube
Looks good. Did it make any difference in how the engine ran?
