Radiator cooling fan relay location
Real quick, I was wondering if anyone knows where the cooling fan relays are? I've seen posts about HVAC relays for the blower motor, but I'm not looking for those, just the relays for the cooling fans.
- '93 Metallic Blue Legacy L, DD w/lots of mods
- '91 Mazda Miata, Autox fun car
Re: Radiator cooling fan relay location
in the relay/ fuse box in the engine bay it should be the first two on the left side
Always open to learn
Hey guys, I got a Legacy 1993 4wd manual 2.2l, I have a problem with the cooler fan and I can not fine the relay... My car doesn't have AC so the car doesn't has the left row neither the top row at all, you can see the box from a Legacy with AC (It is not my box).
So where should be the relays in my case?
According to the wiring diagrams, there is also a "main fan relay" on the interior fusebox.
thanks! I solved my problem
