The post swap clear Sh** out thread.
Now that I have my 92 Swap driving and mostly done, I don't need various things that are, well phase 1.
Most of this probably wont be useful to the majority of the browsers because it's mostly older, but there's some stuff here that might be.
Tbolt clamps SOLD!
Legacy Turbo ECU SOLD!
Legacy Turbo Grille SOLD!
1.5 din SOLD!
Legacy Turbo Black Steering wheel SOLD!
Turbo Legacy Sedan oem turbo back exhaust SOLD!
92-94 Legacy trunk garnish SOLD!
Phase 1 DOHC tensioner bracket for cylinder style tensioner SOLD!
02+ Middle timing cover SOLD!
Stock good BPV from a turbo legacy with bad charge pipe that needs fixed. SOLD!
Aluminum Coolant Tank from some year WRX SOLD!
Turbo legacy hitachi maf with eBay mushroom filter Also fits 91 Legacy SOLD!
Stock EJ22 rods (22t/e) Yes they're the same (Set of 7 rods, 1 was added because of rod knock, they have not been inspected) SOLD!
Turbo legacy engine covers, need some tlc 20.00 each
Turbo Legacy steering rack, Probably should get re-sealed. 100.00
Turbo legacy boost control solenoid 25.00
Turbo legacy pressure sensor (also works on 2nd Gen Legacy. 25.00
Turbo legacy upper coolant reservoir not broken at all. 75.00
1st gen Door panel lights 3 Pictured but I have the 4th on my door panel, painted black originally blue. 25.00
02-05 Coolant Cross Over Tube, Painted Grabber Green, might need touch up. SOLD!
SEVERAL Cam, and Crank sensors. Phase 1 will work on single or dual over head cam. 25.00 each
92-94 Legacy tail lights 25.00 each
There's even a complete set of TGV sensors/motors in there. Unknown condition from the wrx intake manifold and harness I used in my swap. 111k is what I was told when I bought it. 75.00
02+ OEM BPV return hose 10.00
02+ aftermarket bpv plastic block off plate 10.00
Re: The post swap clear Sh** out thread.
CJ,
I'll take the turbo Legacy ECU.
I'll pm you paypal. Call it 60 shipped?
Money sent.
All boxed up and going out within an hour. Had some work delays this morning.
Aluminum coolant tank. 50 shipped.
On bpv 30 shipped. Charge pipe is garbage. Maybe it can be fixed. sold
Bump
bump
thewaterboy
Post by thewaterboy »
Is the grille still available?
Yes.
thewaterboy
I need it. Mine just fell out on the freeway
Bump!
thewaterboy
Is the tall pocket in the last pic for single DIN radios?
yes sir!
thewaterboy
I want ittttt
Buy it when you come to get the grille. Add 20 to the price! 60 total. I'll text you a bit later, it's too early at the moment.
Abeall2
Post by Abeall2 »
WTB Ej22T
90 AWD,5MT,Legacy w/ Ej22t swap.(Silver)
I DO NOT have an ej22t for sale. I mentioned that in my part out you posted in.
I am sorry for being so blunt, but I'm getting pretty tired of repeating myself when questions are asked over and over and the answers are right there in the first post.
Sold the grille and the cubby to thewaterboy
cj91legss wrote:I DO NOT have an ej22t for sale. I mentioned that in my part out you posted in.
To be honest, I have been thinking about this response all morning. Shouldn't have blown up on Abeall2. So I apologize to you. I have been getting asked about the 22t from my part out over and over again, not just on this forum but everywhere else. Nasioc, rs25, sl-i, facebook, and craigslist. I get 10 notifications a day between those sites specifically about the 22t that I specifically post that it is in use. This is not counting the phone calls I receive as well. It gets quite exhausting, and I should hold my composure better for our community. I'm sorry I went all nasioc on you man. You're in WA, so where at are ya located?
