Question for Dan
Question for Dan
You mentioned a Hybrid TD05 a few of us have fitted 2.0l water to air
intercoolers and are attemting to mount the intercoolers on th 2.2t
engine. This is not easy as the turbo discharges at a different angle
than the 2.0l turbo. I have a TDO5H turbo from a MY99 WRX that will
come closer to fitting as the main difference there is the size of the
turbo outlet. But I have been told that this turbo is not one of the
best for use on this engine because of lag. It has a turbine of about
50mm and I was wondering about what the hybrid has that is
different.(I have been studing NZ on the net and it looks like a
paradise to me).
Alan
paradise to me).
Alan
Question for Dan
Paradise alright. Aus it not to bad either but there regulations are
stricter than NZ for Mods.
Yes the TD05 is a bit laggy, which is why it is now a hybrid. Inlet
and exhaust housing changed and well as the impellers , can tell you
much more than that (secret squirrel).
We twist the turbo so we can run straight pipes from the air filter.
Or the Impreza's go under the inlet manifold, then turn at 90 degrees
around the power steering reservoir, then they use a tapered
expansion chamber design from there to the filter, ends up about the
size of a volley ball.
Dan
air
angle
the
the
about
> paradise to me).
> Alan
Dan
air
angle
the
the
about
> paradise to me).
> Alan
Question for Dan
Same question from me [uk turbo] what is the best upgrade turbo ?
----- Original Message -----
To: <BC-BFLegacyWorks@yahoogroups.com>
Sent: Wednesday, May 16, 2001 9:28 PM
Subject: [BC-BFLegacyWorks] Question for Dan
> paradise to me).
> Alan
> paradise to me).
> Alan
Question for Dan
hmmmm, not really sure what the best one is, but my one is pretty
impressive.
Roller bearing turbos are the best, but can't be rebuilt after
failure, and damn expensive to purchase.
Dan
> From: <acroxford@h...>
> To: <BC-BFLegacyWorks@y...>
air
2.2t
angle
will
of the
the
about
> > paradise to me).
> > Alan
> > Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
impressive.
Dan
air
2.2t
angle
will
of the
the
about
> > paradise to me).
> > Alan
Question for Dan
What you are saying makes more sense than what I am hearing here.
Here they are saying that the reason the turbo has lag is the size of
the turbine but I think the turbine was picked to work with the
compressor and the compressor determines the housing. I might have a
doorstop or conversation peice on my hands as finding anyone that
knows what he is doing is difficult. The factory must have nodded off
on this one.
> impressive.
> Dan
to
> air
> 2.2t
> angle
> will
> of the
> the
> about
> > > paradise to me).
> > > Alan
on this one.
> impressive.
> Dan
to
> air
> 2.2t
> angle
> will
> of the
> the
> about
> > > paradise to me).
> > > Alan
Question for Dan
Not wrong, but that is the case for all production cars.
Dan
of
a
off
> on this one.
> > impressive.
> > Dan
turbo ?
water
> to
> > air
th
> > 2.2t
different
> > angle
that
> > will
size
> > of the
of
> > the
of
> > about
like a
> > > > paradise to me).
> > > > Alan
Dan
of
a
off
> on this one.
> > impressive.
> > Dan
turbo ?
water
> to
> > air
th
> > 2.2t
different
> > angle
that
> > will
size
> > of the
of
> > the
of
> > about
like a
> > > > paradise to me).
> > > > Alan
Question for Dan
True, in production almost everything is a compromise. I think I may
bolt this TDO5 on and try the expansion tube trick and also eliminate
any obstruction to the air flow that is already coming from under the
fender to help with the lag problem. I would think it would be an
improvement over the RHB4 IHI that is on there now at high boost it is
really working.
> Dan
> of
have
> a
> off
> > on this one.
pretty
> > > impressive.
> > > Dan
> turbo ?
> water
> > to
> > > air
> th
> > > 2.2t
> different
> > > angle
> that
> > > will
> size
> > > of the
one
> of
> > > the
> of
> > > about
> like a
> > > > > paradise to me).
> > > > > Alan
really working.
> Dan
> of
have
> a
> off
> > on this one.
pretty
> > > impressive.
> > > Dan
> turbo ?
> water
> > to
> > > air
> th
> > > 2.2t
> different
> > > angle
> that
> > > will
> size
> > > of the
one
> of
> > > the
> of
> > > about
> like a
> > > > > paradise to me).
> > > > > Alan
Question for Dan
Sure would be an improvement.
I am not sure that you will be able to get a decent size pipe under
the manifold and around the power steering reservoir, just have a
look, you may need to get another reservoir (not sure though on your
models)
Dan
may
eliminate
the
is
> really working.
models)
Dan
may
eliminate
the
is
> really working.
Question for Dan
I think one could replace the manifold, perhaps with a custom jobbie, and do
very well.
The manifold we have (in the U.S.A.) is crappy. I've had it off once and was
appalled at the guts of the thing. Then I went to a local dealership, and
took a look-see under the hood of the WRX and I would dare say the rex's
manifold is a HUGE improvement. It looks like the pipes are closer to equal
length (on the WRX) and are twisted (in a good way), to provide a more equal
airflow. However, this should only make a significant difference with N/A
engines. When the manifold is pressurized by a turbo, the length of the
tube, angulation, and such, doesn't make as big a difference - because it's
pressurized (once the turbo has engaged, and effectively compressed the air
between the turbine and the valves that is).
Now if that intake went under the manifold as the WRX does, it would also
position itself nicely for a pre-cooler mounted up front, as it is facing
the front of the car squarely, naturally. Finding a way around the radiator
would be a challenge, but with a little madrel bent tubing, easily overcome.
For the N/A types, I would leave it as is (bending around the top, not going
under the manifold). Everytime you introduce a new angulation, or increase
an angle, to a intake header you are effectively making it more difficult
for the engine to pull that air in. From what I understand, front mounted
INTER-coolers are hellatiously lagg-ey because there is sooo much tubing,
and a larger cooler to pressurize (volume). A pre-cooler would make more
sense to me; give the turbo some cooler air to start with, and finish it off
with an inter-cooler before it hits the last of the manifold, valves, etc.
There is no doubt in my mind that our N/A manifolds are crappy and should be
replaced by something with more equal length tubing, better distribution,
less jagged bends, polished, finished properly etc. If it were not for the
fact I'm saving my lunch money to buy and re-build a EJ22T - it would be one
of the first things I might change for the N/A engine.
I have yet to have proven any of these theories, and that is exactly what
they are at the moment. I haven't had the opportunity to really hash this
stuff out with a Subaru turbo genius to see if I'm at all correct. If you
are, or know someone who is, have them get in contact with me. I'd like to
talk to someone who has "been there" with front mount intercoolers,
pre-coolers, etc.
So tell me what you think.
Sorry about the stream of consciousness post. I've been thinking about this
for some time now...
-Sambo
-----Original Message-----
From: daniel.wilson@db.co.nz [mailto:daniel.wilson@db.co.nz]
Sent: Wednesday, May 16, 2001 6:52 PM
Subject: [BC-BFLegacyWorks] Re: Question for Dan
models)
Dan
may
eliminate
the
is
> really working.
very well.
pre-coolers, etc.
-Sambo
models)
Dan
may
eliminate
the
is
> really working.
Question for Dan
Take a look at the file I just uploaded Proeng04 and we can see what
our manifolds should look like. It is the opposite from our manifolds
in that the runners are big on the top and taper down. This is from
pictures taken at Prodrive so I think it may have a price tag on it if
it is avaiable. Anyone have connections in the aluminum casting biz?
--- In BC-BFLegacyWorks@y..., "Sam & Beth Barrett" <LEVATHIAN@s...>
jobbie, and do
> very well.
and was
dealership, and
rex's
to equal
more equal
with N/A
the
because it's
the air
also
facing
radiator
overcome.
not going
increase
difficult
mounted
tubing,
more
finish it off
valves, etc.
should be
distribution,
for the
would be one
what
this
If you
like to
> pre-coolers, etc.
about this
> -Sambo
> From: daniel.wilson@d... [mailto:daniel.wilson@d...]
> To: BC-BFLegacyWorks@y...
> models)
> Dan
> may
> eliminate
> the
it
> is
> > really working.
jobbie, and do
> very well.
and was
dealership, and
rex's
to equal
more equal
with N/A
the
because it's
the air
also
facing
radiator
overcome.
not going
increase
difficult
mounted
tubing,
more
finish it off
valves, etc.
should be
distribution,
for the
would be one
what
this
If you
like to
> pre-coolers, etc.
about this
> -Sambo
> models)
> Dan
> may
> eliminate
> the
it
> is
> > really working.
Question for Dan
Thanks for the story book,
N/A manifold's (well in NZ) have a butterfly system in the manifold
which mechanically opens at 4,500 rpm, why 4,5000 rpm, this rev range
is suited to the cam profile. So there is a huge restriction in the
manifold until 4,500.
Yes the WRX manifolds are much better and bigger, you should also
keep the injectors and use them, modify the air intake to get the
MOST airflow, and replace the fuel pump and you will then be away
laughing.
I am not sure that I follow your pre-cooler idea fully though, if you
have a decent intercooler this mod would make hardly any difference.
Dan
jobbie, and do
> very well.
once and was
dealership, and
rex's
to equal
more equal
with N/A
the
because it's
the air
would also
facing
radiator
overcome.
not going
increase
difficult
mounted
tubing,
more
finish it off
valves, etc.
should be
distribution,
for the
would be one
exactly what
hash this
If you
like to
> pre-coolers, etc.
about this
> -Sambo
> models)
> Dan
> may
> eliminate
> the
it
> is
> > really working.
laughing.
Dan
jobbie, and do
> very well.
once and was
dealership, and
rex's
to equal
more equal
with N/A
the
because it's
the air
would also
facing
radiator
overcome.
not going
increase
difficult
mounted
tubing,
more
finish it off
valves, etc.
should be
distribution,
for the
would be one
exactly what
hash this
If you
like to
> pre-coolers, etc.
about this
> -Sambo
> models)
> Dan
> may
> eliminate
> the
it
> is
> > really working.
Question for Dan
hmmmm, that just looks like a polished version of my STI Impreza
manifold.
Dan
what
manifolds
if
biz?
manifold.
Dan
what
manifolds
if
biz?
Question for Dan
I wish I could get one but it wouldn't fit. But it looks like my
flywheel at least.
> manifold.
> Dan
> what
> manifolds
from
it
> if
> biz?
flywheel at least.
> manifold.
> Dan
> what
> manifolds
from
it
> if
> biz?
Question for Dan
Is your manifold a five peice unit like that one ? I stll keep
thinking of how to make this work. Thinking about WRX ECUs also what
is the rev limit on them ? are there any to be had ? Still keep
admiring the beach I found on one of the NZ sites, even made me
thirsty for a cold beer. I aquired a taste for the good stuff when I
was in Germany for several years.
> manifold.
> Dan
> what
> manifolds
from
it
> if
> biz?
> manifold.
> Dan
> what
> manifolds
from
it
> if
> biz?
Question for Dan
I wish my flywheel looked like that, coming off this weekend.
Dan
> flywheel at least.
> > manifold.
> > Dan
see
> > what
> > manifolds
> from
on
> it
> > if
> > biz?
Dan
> flywheel at least.
> > manifold.
> > Dan
see
> > what
> > manifolds
> from
on
> it
> > if
> > biz?
Question for Dan
Well funny you should mention that, I work in a brewery, DB
Breweries. We brew Heineken, Murphy's Irish stout, Amstel, DB Export
Gold, Monteiths & Tui. A few of the beers you may know.
Well we are surounded by beaches so beaches don't mean much to us.
Except awesome fishing.
Not sure I think it is a 3 piece
The NZ ones changed through the years from 7,800 to 6,500.
Dan
what
I
> > manifold.
> > Dan
see
> > what
> > manifolds
> from
on
> it
> > if
> > biz?
Dan
what
I
> > manifold.
> > Dan
see
> > what
> > manifolds
> from
on
> it
> > if
> > biz?
Question for Dan
Oh yes and this is one thing I was concerned about. Although I am
partial to a good Pilsner there are many others. I really would like
to get out of this crowded world of the overly regulated. Just
yesterday a Jeep SUV passed me and he was flying, when he swerved back
in to the lane I could see daylight under one of the rear wheels. I
hate to think about the time when these things get old and are on the
road driven by people who cannot keep them in good repair. I wonder if
that manifold would even come close to fitting a EJ22t ? I saw the
butterflys in the runners in a SAE paper I have and was thinking that
they would have something to do with keeping velocity up. The power
available when the intake and exhaust are tuned right is staggering. I
was asking about the ECU because it might be adaptable to my engine. I
have worked in Electronics all my life and managed to "trick" one of
our ECUs in to 8500 rpm but it pretty much fell on its face on the top
end. At the time I thought valve float but now know about the fuel
problem.
Alan
> Dan
> what
> I
> > > manifold.
> > > Dan
> see
> > > what
> > > manifolds
> > from
> on
> > it
> > > if
casting
> > > biz?
problem.
Alan
> Dan
> what
> I
> > > manifold.
> > > Dan
> see
> > > what
> > > manifolds
> > from
> on
> > it
> > > if
casting
> > > biz?
Question for Dan
Our Montieths brand brew an outstanding Pilsner, the best I have
tried.
I don't personally like the butterfly setup so are going to ditch it
soon.
I have just spent the last 3 hours trying to get my flywheel off,
with a rattle gun, no luck, now I have to try to find some gas
bottles for my gas set.
Dan
like
back
the
if
that
staggering. I
engine. I
of
top
> problem.
> Alan
Export
us.
> > Dan
> > what
when
> > I
Impreza
> > > > manifold.
> > > > Dan
can
> > see
> > > > what
> > > > manifolds
is
> > > from
tag
> > on
> > > it
> > > > if
> casting
> > > > biz?
tried.
soon.
Dan
like
back
the
if
that
staggering. I
engine. I
of
top
> problem.
> Alan
Export
us.
> > Dan
> > what
when
> > I
Impreza
> > > > manifold.
> > > > Dan
can
> > see
> > > > what
> > > > manifolds
is
> > > from
tag
> > on
> > > it
> > > > if
> casting
> > > > biz?
Question for Dan
Dan-
Do you have the flywheel stopped in place so it doesn't spin while you
wrench on it? If not, try that 1st.
jason
Get your FREE download of MSN Explorer at http://explorer.msn.com
Dan-
jason
