Hi, I am a Legacy owner from Perth, AUS. I had a Legacy/Liberty which have power steering pump problem.
I aleady changed twice, but all of them work for awhile, then break down....no leak, but just not working...pump itself stop turning, even with new fluid(correct fluid) put on..
I am thinking of rebuilding this non-working PS Pump.....what must I do? Why it can't spin?
Rebuilding non-working P/Steering pump
libertyperth
Re: Rebuilding non-working P/Steering pump
Welcome to the BBS.
Please take a look at this thread with info & pictures on rebuilding the power steering pump.
http://bbs.legacycentral.org/viewtopic.php?f=11&t=24143
It's possible the bearings are seizing or the pump internals may be seizing. You would need to disassemble things to determine which is the problem.
