Slight engine knock
humphreys1588
Slight engine knock
Post by humphreys1588 »
https://vimeo.com/129804423
Thanks in advance for the feedback guys!
This is what I'm hearing at idle when it's warmed up. Could this be due to low idle issue?
TurnNburn
Re: Slight engine knock
Post by TurnNburn »
Seems way to inconsistant to be a engine knock. And also seems very hallow and plastic'y. Does it get worse with RPM's? Do you have access to a stethascope? would help pin point the noise.
Just from the short video i would guess something is hitting your timing cover. Would be worth taking the covers off and looking in there. At least the 2 side fronts.
Once those engine covers, front or rear, get oil on them they can distort and flex, maybe its touching one of your pullies? Just a guess
1990 NA 2.2 Open Light rally car
Yeah, I agree it sounds a bit too intermittent and would recommend taking the timing covers off.
RoughDiamond
Post by RoughDiamond »
Almost sounds like a belt slapping the timing cover... I'd almost gamble your hydraulic tensioner is either dying or loose.
1991 Legacy SS (BC) EJ22T // 4EAT // Pewter Metallic (Sold)
1991 Legacy SS (BC) EJ22T // 5MT // Rio Red (Sold)
1991 Legacy SSRS (BC) EJ20G (Full COP and AWIC Swap) // 5MT // White Pearl Tri-Coat Africa Rally replica in progress.
