95 WRX transmission noise
Baddog
Post by Baddog »
Hello there,
Looking to see what this problem could be. Not sure if it is the center diff or I stretched first gear.
The car is a 95 Impreza L with an EJ205 swap and a 95 JDM WRX transmission. Took the car to the drags on Friday night. 2nd run I broke a few teeth off the spider gear in the rear differential. Replaced the differential with a known good one (also a 4.11).
Been driving the car and having this whining noise now on deceleration. Also when accelerating in first gear sometimes I hear what almost sounds like a rock tumbler for a second or so at low RPM's. Goes away at higher RPMs.
The noises are not apparent in any gear other then first.
https://www.youtube.com/watch?v=AyqCnRQ ... e=youtu.be
https://www.youtube.com/watch?v=ZzpAms7 ... e=youtu.be
1996 Subaru Legacy L
1993 Subaru Legacy SS
1992 Subaru Legacy L
1990 Subaru Legacy L
Re: 95 WRX transmission noise
Did you swap the entire rear differential or just the gearing into the existing housing? If the latter did you check gear back lash?
Baddog
Post by Baddog »
I swapped the full rear differential. Didn't swap over any guts.
Pntaste4evr99
Winestone Cowboy
Post by Pntaste4evr99 »
My first gear kinda sounds the same....but only when cold?? Weird
94 Winestone SS 5MT Rob 550 20g. (Pickle)
Original WA car with 460k miles and climbing
Pntaste4evr99
Winestone Cowboy
Have u blow through clutches constantly launching like that in your drag videos?
Baddog
Post by Baddog »
Clutch only has about 1k miles on it. So nope haven't blown through one yet.
