Only at 4 psi boost.
SomeOldHobo
Post by SomeOldHobo »
So just installed a boost gauge and im running at a steady 4 psi boost. Boost leak? Fully stock except 3" turbo back.
Re: Only at 4 psi boost.
Limp mode.
Can you provide some more details on your setup, whether you have a manual boost controller, running stock ECU, etc., etc.
