Swapping mafs
Swapping mafs
I have a 91 leg n/a mt. With a hitchaci maf the aluminum one, can I put the jecs black plastic one on or will it not jive?
Re: Swapping mafs
Gotta use the metal MAF or convert to the newer ECU to match the plastic MAF. Otherwise they aren't interchangeable.
Re: Swapping mafs
Ok. Just wanted to make sure before I got one because I keep seeing it for the auto trans
Re: Swapping mafs
Also the injectors are different and would need to be swapped as well
1990 NA 2.2 Open Light rally car
Re: Swapping mafs
So what would I need to do to allow it to read more air? Get a stand alone?
Re: Swapping mafs
To read more air and not run like shit, Yes
