A/C fuse in engine compartment blows
Posted: Fri Aug 07, 2015 11:48 pm
by stoc1173
I've been fighting my a/c for a while now. Finally it quit. Everything checks out including pressure switches, relays, clutch ... I found the a/c 10A fuse blown, replaced it and it immediately blew again. Tried a 20A fuse, Blew! Jumped the a/c clutch to the battery through an ammeter, Works fine, draws less than 3 Amps. Where do I go from here?
92 Legacy AWD wagon 5MT
Re: A/C fuse in engine compartment blows
Posted: Sat Aug 08, 2015 8:45 pm
by stoc1173
Thanks for the tip. I pulled the whole thing apart, inspected every wire and connection and found nothing that raised suspicion. then I pulled all the relays, reconnected the negative battery terminal and started the car. The fuse was still good. the instant I hit a/c it blew even with the relays were still out!. I'm pulling my hair out. Could a bad controller cause this? I have a different one coming in any day now.
Separately, I replaced the relays, pulled the fuse, jumped the compressor to the battery and it blew cool wonderful a/c through the vents even with the fuse removed.
Posted: Sat Sep 12, 2015 3:32 am
Did you ever get this resolved?
This is for the 90 Legacy, but may give you some additional troubleshooting routes.
http://main.experiencetherave.com/subar ... g_Diag.pdf
