Clutch wont engage help!
Ej22tfun
Post by Ej22tfun »
Alright so i just finished swapping motors from my 92 legacy ss into my 91 ss. Everything is great except for the fact that my clutch wont engage. I can start the car but i have no clutch pedal. Im not sure what happend becuase neither of the cars had amd issues with the tranny prior to the swap so it has to be something i did wrong but what could it be? I know i put the throw out bearing in the correct way and ive bleed the clutch but im not sure where to go from here
2003 wrx wagon (stock),1992 subaru legacy SS, built 1991 subaru legacy SS
Re: Clutch wont engage help!
Can you provide any additional information as to what you've done to troubleshoot the problem?
WRXish
Post by WRXish »
I'm having the same trouble....at a total loss to understand it
zeke
Post by zeke »
Did you recently do anything with the clutch and does your car have a turbo transmission or a na trans?
91 ss Ej22t dohc td04 sti Slanty haltech elite 1500
WRXish wrote:I'm having the same trouble....at a total loss to understand it
I thought you had a non-turbo car with cable transmission? If so this would likely be a completely different issue than what the turbo transmission was likely dealing with.
