So I had the car up on jacks today. I started the car and put it in first. The rear end was making a knocking sound and the right front was not spinning. When I drive the car pulls hard to the left especially starting from a stop. I know it needs a clutch. I recently took it off road hard.
Is it normal for only one front to spin when the car is in the air. Could it be a problem with the half shaft?
5speed awd 167000 miles sedan 2.2 na
1 or 2 problems?
thisisforhondas?
1 or 2 problems?
1993 L wagon (receiving wrx heart)
2001 outback
2002 wrx
91 ss 5mt
91 sedan AWD 5mt
2001 outback
2002 wrx
91 ss 5mt
91 sedan AWD 5mt
Re: 1 or 2 problems?
It is normal for only one front to spin. The car has an open front diff.
thisisforhondas?
Okay. But if the rear is open diff too why did both spin?
2001 outback
2002 wrx
91 ss 5mt
91 sedan AWD 5mt
2001 outback
2002 wrx
91 ss 5mt
91 sedan AWD 5mt
If there's more resistance on one side or the other, that side will stop and the other will spin. If the resistance is equal, both will spin. You should be able to stop or slow down any spinning wheel and the opposite side should start spinning or speed up. If not, there's some other problem.
Is the wheel that doesn't spin hard to turn by hand you could have a brake that is sticking
91 ss Ej22t dohc td04 sti Slanty haltech elite 1500
thisisforhondas?
The knocking was mud on the wheel. Could I have an lsd?
2001 outback
2002 wrx
91 ss 5mt
91 sedan AWD 5mt
2001 outback
2002 wrx
91 ss 5mt
91 sedan AWD 5mt
Unless it's a 91 turbo probably not, unless someone else put a lsd in. If you look at the tag on the rear diff it will say vlsd if the tag is still there.
Have you checked the brakes yet?
thisisforhondas?
Brakes are perfect
2001 outback
2002 wrx
91 ss 5mt
91 sedan AWD 5mt
2001 outback
2002 wrx
91 ss 5mt
91 sedan AWD 5mt
I would spin the right tire and see if the other tire spins the opposite direction. If it doesn't I would grab the axle as close to the transmission and have someone spin the wheel to and see if the axle is bad.
