EJ22T motor phase 1 with a fully closed deck and oil squirters for piston cooling SOHC. harden steel gears in manual 5 speed transmission. duel piston caliper brakes. tinted sunroof and windows. wrx rims, rally horn, LED lights.
Extras
turbo hood, white
front and rear turbo style bumpers maroon
Both front doors with glass and side mirrors not tinted and passenger rear door with glass maroon
rebuilt heads still in the box
CPU
Kaiser aluminum "A" pillar brace
turbo (needs full rebuild)
rear shocks KYB GR2 gas shocks, used
some extra interior pieces like center console plasic pieces
okay so here is his situation. I was using him as a daily driver until I lost the #3 cylinder which dumped oil from my air filter to the catalytic converter. the spark plug melted in the 3 hole so I'm sure it needs piston and rings. I have 2 turbos for it. one was hitting at 11lbs(needs oil seal) and the other needs a complete rebuild. the heads that are on it are fine but tired, that's why I have rebuits ready to be installed.
all extras must go with the car. $3,000 cash only and bring a trailer.
I have been trying to get pictures on here for a while without success. I have the car posted on Reno and Sacramento craigslist with pictures.
93 legacy AWD Turbo. ej22t phase 1 motor closed deck
No partouts or individual parts sales.
All auctions or local sales should be in the Craigslist/eBay forum
93scoobynv
93scoobynv
Re: 93 legacy AWD Turbo. ej22t phase 1 motor closed deck
sorry, scooby is maroon with black interior
robertpaige
Nice Legacy, but i'll be honest in my opinion, you won't have luck selling an SS with a blown 22T for 3k. The 1500-2200 range is more appropriate. GLWS!
You need to upload the pictures to a website like photobucket and use the address links by the pictures to post photos...
dscoobydoo
Since you are not far from LA ( like less than five hours), you could find a 20g and swap it in still run the stock setup.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
05 GD-STI
00- GF
