Interested in a complete, turn key and log booked stage open light rally car? Now is your chance. This car is all done and ready to rally. This car was bone stock when I got it so all of the modifications are new with very low miles, iv owned the car for less then 3k miles. And I just put in a rebuilt engine. Drives and runs great and is definitely daily driverable, transmission shifts well, no check engine lights, no leaks, no body damage or rust, everything works, clean chassis with a clean title in hand.
200k miles on chassis
50 miles on completely rebuilt motor
Delta 230 (horsepower grind) camshafts
New spark plugs and wires
New O2 sensor
New injectors
New wrx fuel pump and fuel filter
New coolant temp sensors
New knock sensor
New STI water pump (to use an STI oil cooler)
New thermostat
New radiator
New exedy clutch and light weight flywheel.
Log booked roll cage (SCCA approved and built to current Rally America specifications)
OMP HTE racing seats
G-Force 6 point harnesses
WRX brakes in the front with new calipers, slotted rotors and pads (larger then stock)
Legacy GT rear brakes with new calipers, rotors and pads (larger then stock)
Stainless steel brake lines
Ksport 55mm rally suspension (just did alignment) with heavy duty coilover covers (I have 4 spares for the front and 4 four the rear)
22'' LED light bar
2 7'' HID lights
DOM tubular light bar
Reinforced sub frame
Skid plate-aluminum 1/8''
Steel rear diff guard
HDPE under body protection
Flocked dash
Carbon Fiber roof scoop
Primitive roof vent
Momo steering wheel
Momo hub adapter
Momo quick release
Rally America approved spill kit
3 fire extinguishers
2'' manifold back exhaust w high flow cat
AEM wideband sensor with gauge
Vacuum sensor/gauge
CB radio(installed but not wired)
Terra-Trip terra-coms intercom system(installed but not wired)
Coleman 2:1 quick steer reducer (not installed)
CNC brand hydraulic hand brake and a adjustable brake proportioning valve (for use with the install of the hand brake, not installed).
Comes with spares of almost every part on the car, the list is very long but here is most of it:
12 competition rally tires
4 spare 15'' alloy rims
4 16'' stock alloys with new summer tires
wrx springs/strut assemblies for all 4 corners
Heads
Intake manifolds
The original brake components(rotors, lines, calipers and pads)
Rear subframe
Front and rear wrx and sti sway bars
Several lateral links for both sides
Trailing arms for both sides
4 knuckles with hubs and good wheel bearings (1for each corner)
Rack and pinion that has inner and outter tie rods on
Radiator with fans
Both front fenders
All 4 doors
Hood
Trunk (with turbo wing)
Head lights
Corner lights
Tail lights
Power steering pump with lines
Alternators
All four axles
Steering column
Stock STI steering wheel
2 oil pans
And a few other suspension bits and lots of extra tubing/hoses, adapters, I cant think of right now. All of these parts are off the car and in boxes. You can take as much and as little of this stuff as you want/need.
Will come with my racing gear as well, if you are my size and rock XL's (i am 6''2)(only used for 3 days): Pyrotect 1 piece race suit, fire proof leggings, shirt and socks, driving gloves, helmet and driving shoes in size 12
I cant possibly add enough pictures to describe the car very well but am more then happy to take pictures of whatever you want. I am only asking 10,000 for everything OBO. I have put in about double that in parts and labor so it is priced to sell and is my loss and your gain. The roll cage alone cost almost $4000. Test drives will only be given for serious buyers with money.
I am interested in partial trades for a AWD Chevy Astro or GMC Safari vans depending on condition
Click on the craigslist add to see more pictures:
http://bend.craigslist.org/cto/5461623125.html
