Stock intake with td04?
Can I use the factory intake set up with a td04? Thinking about doing the swap soon.
Re: Stock intake with td04?
I've seen people buy silicone elbows in the appropriate sizes to make it work. Most use the opportunity to upgrade to a tmic, however.
Yes, you will need to buy a 90 degree silicone elbow that 2.25" in size, then cut a piece of pipe so that you can clamp the new inlet to the turbo elbow.
I currently have an 06 tmic plummet up to my vf11. I understand I have yo reroute the my plumming to the outlet as well. Shouldn't be that hard. As for as the outlet, I just need the 90' elbow and a piece of pipe yo connect to the stock air box?
