Coat your cams!
Imprezive
Coat your cams!
Post by Imprezive »
Back when I did a lot of work on Spec Miatas here in California there was always talk of "coating" engine, transmission, and differential internals. I never knew what this coating was, and I doubt anyone else did either. I'm sure some of you are aware of it, though.
Anyway, I'm doing a Rhetorical analysis of a scientific Engineering based article of my choosing for a class, and happened to find this article which I thought was pretty interesting:
http://www.sciencedirect.com/science/ar ... 9X06001484
Its a short article and offers up a cool result. The catch I thought was interesting is that the different lubricant used drastically reduces the friction coefficient when using the ta-C type DLC coating. Anyone have experience using coatings for engine parts?
1988 4Runner RIP
2006 Suzuki DRZ400sm
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
jamal
Vendor
Vendor
Re: Coat your cams!
Post by jamal »
I have had a few things WPC treated. One was a new gear set for a guy with a modded LGT that seems to still be holding up. WPC can be used on bearings and other engine parts as well to reduce friction. It's like shot peeing, but with very small particles:
http://www.wpctreatment.com/about.htm
http://www.motoiq.com/MagazineArticles/ ... t-WPC.aspx
And then there are a few pistons that come with coatings, like mahles and the skirts on cosworths. They tend to wear off after awhile though. I think DLC is more durable?
Imprezive
Re: Coat your cams!
Post by Imprezive »
jamal wrote: It's like shot peeing, but with very small particles:
lol, typos are fun
I haven't heard of WPC until now. That seems pretty cool!
1988 4Runner RIP
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
Re: Coat your cams!
It appears to be something similar to work hardening a surface, but on a very small scale. This leaves the surface smoother and harder.
